dataclass_documenter package
Submodules
dataclass_documenter.block_meta module
YAML block metadata.
class dataclass_documenter.block_meta.BlockMeta(indent_unit: str = '  ', indent_level: int = 0, commented: bool = False, first: bool = True, in_list: bool = False)[source]
Bases: object
Metadata for YAML blocks.
Parameters:
  • indent_unit – The string to repeat for each level of indentation.
  • indent_level – The indentation level.
  • commented – True if the entries should be deactivated by comments.
  • first – True if this is the first block within its context.
  • in_list – True if this block is containined in a list.
__init__(indent_unit: str = '  ', indent_level: int = 0, commented: bool = False, first: bool = True, in_list: bool = False) → None[source]
commented: bool = False[source]
property commented_indents[source]
Same as indents but with forced commenting.
first: bool = True[source]
in_list: bool = False[source]
indent_level: int = 0[source]
indent_unit: str = '  '[source]
property indents[source]
The field and non-field indent strings based on the current block context.
dataclass_documenter.dataclass_documenter module
Generate documented YAML files from documented dataclasses.
class dataclass_documenter.dataclass_documenter.DataclassDocumenter(datacls, name=None, width=120, indent_unit='  ')[source]
Bases: object
Generate markdown and YAML documentation from documented dataclasses.
__init__(datacls, name=None, width=120, indent_unit='  ')[source]
Parameters:
  • datacls – The dataclass class or instance to document.
  • name – The name to use for this class in the documentation. If None, the name of the dataclass will be used.
  • width – The target output width for wrapped comments.
  • indent_unit – The string to repeat at the start of each line for each level of indentation.
property docstring[source]
The parsed docstring.
property fields[source]
The fields of the dataclass.
get_markdown(level=0)[source]
Get a markdown description of the dataclass that contains a commented example YAML input file.
Parameters:
level – Markdown header level.
Returns:
The markdown string.
get_param_desc(param, default=None, warn=False)[source]
Get the description of a parameter.
Parameters:
  • param – The parameter name.
  • default – The default value to return if the parameter lacks a description.
  • warn – If True, log a warning when the description is missing.
Returns:
The parameter description.
get_param_type(param)[source]
Get the type of a parameter.
Parameters:
Returns:
The parameter type.
get_yaml(level=0, commented=False)[source]
Get commented YAML input for the dataclass.
Parameters:
  • level – Markdown header level.
  • commented – If True, comment all lines.
get_yaml_blocks(level=0, header=None, commented=False, origin=None)[source]
Parameters:
  • level – The indentation level.
  • header – An optional header to emit as a comment at the start of the output.
  • commented – If True, comment all fields.
  • origin – The optional container type for this object, either dict, list or None.
Returns:
A generator over blocks of YAML.
property params[source]
The dict mapping parameter names to DocstringParam values.
dataclass_documenter.main module
Command-line utility for generating dataclass documentation.
exception dataclass_documenter.main.DataclassLoaderError[source]
Bases: Exception
Custom exception.
dataclass_documenter.main.import_dcls_from_file(path, name)[source]
Import a dataclass from a filepath.
Parameters:
  • path – The path to the file containing the definition of the dataclass, as a pathlib.Path object.
  • name – The name of the dataclass.
Returns:
The dataclass.
dataclass_documenter.main.import_dcls_from_module(module, name)[source]
Import a dataclass from a module.
Parameters:
  • module – The module name. It must be importable.
Returns:
The dataclass.
dataclass_documenter.main.main(args=None)[source]
Generate Markdown or YAML for a dataclass.
Note that this will load the module containing the target dataclass and thus execute any top-level code within that module.
dataclass_documenter.main.run_main(args=None)[source]
Wrapper to run main().
dataclass_documenter.typing module
Typing functions.
dataclass_documenter.typing.get_type_name(typ)[source]
Get the name of a type.
Returns:
The name as a string.
dataclass_documenter.typing.is_optional(typ)[source]
Check if a type is Optional.
Parameters:
typ – The type to check.
Returns:
True if the type is optional, False otherwise.
dataclass_documenter.typing.strip_optional(typ)[source]
Strip outer optional types.
Parameters:
typ – The type to strip.
Returns:
The first non-optional type within the type.
dataclass_documenter.typing.type_to_string(typ)[source]
Get a string representation of a type. Optional types are stripped down to their underlying type.
Parameters:
typ – The type to represent.
Returns:
The string representing the type.
Module contents
Package stub.
class dataclass_documenter.DataclassDocumenter(datacls, name=None, width=120, indent_unit='  ')[source]
Bases: object
Parameters:
Parameters:
Returns:
Parameters:
Returns:
Parameters:
Returns:
The parameter type.
Parameters:
Parameters:
Returns:
